Looking to replace head Gasket.
Joseph Davis
Lompoc, CA
My truck seems to run good but my radiator started to build pressure shortly after started, about 1 min. cooling system is holding pressure but the extra pressure probably will blow radiator. the pressure is 15 psi in one min. But on the IDI can I pull the heads off the block while still in truck if I put 2x4 block under the engine mounts. When I changed my push rods last year I did this to make it easier to get valve covers off. I have the Chilton's but it says pull motor. Can this be done in the truck so I don't **** off my landlord. I just have a small garage truck won't fit.
renjaminfrankln
Raleigh NC
Have not done it myself, but I believe many members here have done it. It will be tight, but doable, especially if you are sticking with head bolts and not doing studs.
You may also want to remove the injector pump, intake, and valley pan before trying to pull the head. This will give you more room. It will also reduce the chances of damaging your new head gasket while installing the head. I would also recommend a helper to grab the head after you remove it and to lift the head up for you to grab while you're installing it. I HATED the idea of trying to climb into or out of the engine compartment with a head sitting on the core support. A dropped head can cause A LOT of damage to it, you, or both.
Joseph Davis
Lompoc, CA
Yea sticking with head bolts just going with new ones and will just up date the heads with what ever is in the forecast for new parts.
Joseph Davis
Lompoc, CA
You bet put the new injection pump in and could not even think about damaging that. Taking whole top end off.
I never did use anything on the back sides. The driver's side wasn't too bad since it has the square bosses on the back. The passenger's side was a PITA since it's pretty smooth. Just bee careful if you wear the gloves while installing the head. They could get caught underneath the head when you set it back on. It probably wouldn't do any damage, but I wouldn't recommend taking the risk.
Joseph Davis
Lompoc, CA
I got my cherry picker and I usually pull every thing so I can inspect every thing. looking to pull the heads off Saturday. Only thing looks to be a problem is the back head bolt location for torqueing. Thanks for all the info Oil Burner's
Jimmy Stewart
Florida
I just did this. It’s not a whole lot of fun but worth it. That cherry picker will save you.
truckonfire
