lift pump failure questions
01 SD
was low on fuel the other day and took my boat to the launch ramp.
then it started acting weird.
threw high to low codes
and ICP codes.
let it sit for a day and went to work on it
fired it up and it ran like normal
filled the tank
test drove it and all was well,
on the way home, it started acting up again.
ICP is at 500+ when cranking
but all of this tells me I have a *****'d lift pump
thoughts?
Have you been into the tanks at all?
Could be the pickups. But pump is "cheap."
But.... I would start with the icp. Those dudes will cause all sorts of weird running.
already swapped out ICP no change.
tanks have been modded and gone through
06 F450 rear tank
the e-pump is off the parts truck and has been sitting for Thor knows how long
Could just be junked up.
Did you ever get the injector clack from air or anything like that?
oah yea, it sounds like its starving for sure.
atleast that's what my inexperience tells me lol
Then I would start there.
I've seen people have the inertia switch act funky too. Even though they weren't in a wreck or anything.
I hate those switches, I should delete the damn thing lol
FarmerFrank
Blairsville, Pa
The obs have a Schrader valve. I would assume the SD do also.
Just worked on an SD hpop last night. Didn't see any Schrader valves when I pulled the fuel bowl
no Schrader valve that ive seen,
e-fuel.
not gonna get to this truck until next week
IDIBronco86
