pybyr
Passing along the trouble-shooting process in case it may help someone else with the Leece-Neville 165 amp alternator (used on emergency vehicle fit-ups on the F Series).
Since I'd been told by multiple sources that the regulator is one of the few things that goes bad on these alternators, I ordered one and got it today. Pulled the alternator, put in the new regulator, put the alternator back on-- still no output.
So... took off the pulley and fan, removed the three long through-bolts that hold the alternator casing together around the stator, and carefully tapped the thing apart. Removed the main rectifier packs, and tested with a multimeter on diode-check function. Negative rectifier assembly checked out OK; positive rectifier assembly was kaput on all three of the individual diodes-- _no wonder_ I was getting zero output... Rotor checked out appropriate winding resistance, and no shorts to shaft. Stator windings all had continuity, and no shorts to case.
So at least now it's clear what needs to be done to get this unit up and running. A shop about an hour away has the rectifier modules, and is open Saturday AM, so off I go in the morning.
I do have to agree with what people told me about the build quality of the Leece-Neville alternators: this thing is Hell for Stout.
I'm now remembering something I was told about a month after I bought the truck-- that the reason it had two new batteries is that one of the volunteer FD members had dropped a wrench across the battery terminals and there'd been a huge arc. I'm now guessing that the rectifier took a hit, and maybe even one or more of the diodes went out, causing the remaining ones to carry a higher load, and leading to their eventual demise.
Hopefully I'll be able to report tomorrow that the unit is charging again.
Thanks for the support 'round here.
