rhkcommander
Wire in resistors to add load or splice in an led bulb with turn signal, see what happens
Agreed, although I've been trying to find one and haven't yet.I think theres a LED specific flasher
You're probably going to have to look online. It would be easier if you have your old flasher onhand when looking. I think the OBS trucks use a different flasher design than '80-'91 trucks, which is part of why I haven't found anything (I'm also too lazy to go out to my truck and grab one of my flashers). If a flasher is the same size and has the same terminals as yours, it should work...and, just make sure that the one you have is compatible with LED bulbs.All the parts stores I've talked too don't have a clue
Here's an example of an LED-compatible flasher, although this is for '99+ SuperDuty trucks...
http://www.truck-lite.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&productId=32102
