There is a weep hole at the back - bottom, it means your pump is failing, sorry, same happened to me, I looked with a small mirror while it was running and saw it "weeping" out. It drains out the back, across the valley pan and down onto your starter, if your starter is wet(with diesel) that is what is happening
