leaking plug on hpop
94f450sd
somewhere,ma
On the front of the hpop on the passengers side there is a big hex plug that i believe is leaking.besides the oring whats under that plug?ive never taken an hpop apart,i dont wanna pull this plug out and have pieces or something important fly out of it.
if i get a minute today, ill take the one i have on the shelf apart.
mine is off a 97, dont think that matters tho
crazytwo
SF, CA
I don't know what year you have but I just changed one of the O-rings on my Excursion this week. It was on the drivers side and fairly easy to get to. I used the $12.50 kit plus $2.50 for First Class postage. I am posting a link to a more complete kit with probably all the O-rings in your pump. I would call them up (Riff Raff Diesel)and send them a picture of what you need. That is what I did. Good luck.
http://www.riffraffdiesel.com/extended-hpop-o-ring-kit-with-full-hose-fitting-repair-kit/
P.S. This is from the 99-03 section.
94f450sd
somewhere,ma
In the picture i posted,its the plug circled in red where the dudes hand is on the right side of the pump.
720Diesel
