Know what these GPR voltages mean?
BigRedWeather
Lexington, KY
I would swear I had already posted this... but I can't find it now. I 'll try again
The four wires going to the GPR all go into the wiring harness about 4 inches from the GPR. They all look good up to that point.
Whenever I turn the key on, whether engine is hot or cold the WTS light comes on for 1-2 seconds.
LEGEND
Four posts on GPR
sL small left
sR small right
BB Big, connected to Battery
B, the other big post
G battery negative post
G-sR means volt meter test leads on G and sR
CLICK- click heard right around the GPR about 30 seconds after the key is turned on
ENGINE COLD (OUTSIDE TEMP 70 F) KEY TURNED ON, BEFORE CLICK
G-sR 12v
G-sL 0.5
sR-sL 10.8
G-B 12
ENGINE COLD KEY TURNED ON, AFTER CLICK******
sL-sR 0
G-B 0
BB-B 0.6
G-sL 12
G-sR 12
ENGINE HAS RUN FOR 40 SECONDS, ENGINE TURNED OFF, KEY ON AFTER CLICK
sL-G 12
sR-G 12
G-B 0
sL-sR 0
ENGINE RUN FOR 30 ON HIGHWAY, ENGINE TURNED OFF, KEY ON BEFORE CLICK (I DON'T RECALL IT I EVER HEARD A CLICK
sL-sR 6v
u2slow
bilge rat
Coastal BC
The 10.8V suggests to me that the glowplugs are on at that point. The high current draw (load of the GPs) causes the voltage to dip below 12v.
