The cowl. Our '95 trucks have A/C and no such vents. They just put some plates over those openings behind the trim panel. Evidently it makes for a very cozy place for mice to set up housekeeping.
Easy to swap them in. Find kick panels with vents and just remove the block off plate held in with 4 bolts. Seems most factory AC trucks didn't have them. Also you'll want to clean this area out behind the vent or blockoff plate every now and again.
