1994IDI
I finally bought some gauges for the truck. I was at the parts store ordering, and long story short, I left with 3 autometer sport comp gauges (pyro, boost, water temp), a new tool box, and the j clamp mounts that don't require drilling. I've been pretty excited to finally have bought all this, it's like driving a new truck. I did go with all mechanical gauges, so those who chimed in with advise on that topic last week, thank you. I plumbed the water temp into the over temp sensor port, and it worked like a charm.
I got the gauges in last Friday, and have since turned the pump up about 2 flats. I have seen a noticeable increase in black smoke. Mostly that it is now black instead of gray. My numbers are as follows.
STOCK
EGT- 55-60 mph: 550-600 F Floored: 800 F max
BOOST- Max: 6 psi
WATER TEMP- 195 F
PUMP INCREASED
EGT- 55-60 mph: 600-625 F Floored: 950 F max
BOOST- Max: 7 psi
WATER TEMP- 195 F
All of these results were unloaded, on level ground, in about 55 F weather.
Just thought these numbers may be useful to anyone considering increasing there pump. Let me know what you think.
STOCK
BOOST- Max: 6 psi
WATER TEMP- 195 F
PUMP INCREASED
BOOST- Max: 7 psi
WATER TEMP- 195 F
I turned it back down this morning.
