jlwoods99
SO after a new champion aluminum radiator. Carrier electric fuel pump, new steel fuel return to FSV and steel supply from FSV . Return line kit much rewiring of cobbled up wiring to all the add ons. It fired up tonite, it's got distilled water in it to flush it out after I blew a upper hose this summer and the radiator was full of cotton from the hose. I've gotta get a couple flushes thru it before the freezing weather sets in here in the cold north.
My question to ya'll is in the carrier fuel pump I see in the bowl about 1" of air above the fuel level. I've bled the fuel filter at the schrader valve. The truck is running fine, is this normal not being hydraulicly full in the carrier fuel pump?
Thanks
Jim
Thanks
Jim
