installing new gauges, need a quick answer
GRU
fear the chicken legs
fredonia pa
i bought a completely new set of gauges. egt, boost oil press and temp gauge. problem is im completely new to these motors and have no idea where the coolant temp sensor and oil pressure sensor is located!:dunno can someone toss me an answer please? thanks alot!!;Sweet
Chevyboy_0
Mr.SunnyDisposition
Livermore, Ca
I know the oil pressure gauge is located at the top part of the motor bythe firewall, at the back end of the valley pan, but I'm not sure where the water temp is, if I had my guess it would be in the drivers side of the motor either in the head or the side of he block. But then again I don't know
crash86
texas
the water temp is up in the front of the motor on the driver side
GRU
fredonia pa
there are 2 sensors up front. one looks to be on the water pump kinda beside the oil fill tube. the other is at the very front of the driver side exhaust manifold. which one?
tjb
Aztec, NM
my 6.9 has them both up front the one on top is for coolant and the lower one is oil.
hoodshauler
PARKER, CO
the one on top of the water pump is recomended but you can use the one on the head too.. Also the oIl sensor on a factory ats turbo is at the turbo oil tube connection.
