Injectors with return kit
Diesel JD
Gainesville, FL
See what you can get man, the early small return system would probably be better. Mostly concerned about the return that goes to the hard line back to the tank, in terms of a newer return kit.
redneckaggie
rebel w/o a cause
angleton/stephenville tx
What model kit is my truck i already had an early model kit that i was going to put on my truck when i found that the injectors were bad and i realized that the caps look different.
Diesel JD
Gainesville, FL
Hey redneck, your truck is a 7.3 it should have the later model kit, with the bigger return lines and fittings on the caps.
New Delphi's will come with the copper washers installed, so any you get in your return line kit will be surplus.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
Russ, do you by chance have the facilities to rebuild/test/match non-IDI injectors? A friend of mine has an M-B 240D (I'm actually borrowing it from him at the moment :angel: ) with what I'm pretty sure are *****'ed injectors...
Thanks! ;Sweet
Thanks! ;Sweet
tim-
i have a used set that needs rebuilding sitting on the shelf right now.
they came off what's left of Lisa's car.
typ4
Newberg,OR
Thanks! ;Sweet
Yeah ,with Brandon doing his stuff we have some MB parts around. The threads are the same as an IDI.
Mat J
Way down south
Jupiter, FL
I also might be in need of a return line kit hard air in the fuel today out of nowhere.
How much for a kit and does it come with washers and can you get the clear line?
typ4
Newberg,OR
Chevyboy, kit comes with hose, clamps, orings, caps and copper base washers.
The early kit is 6.9 and the first year of 7.3 or so I am told. The late has bigger line and different caps, all will fit with a hose mod or 2, the turbo kit is not available from this supplier, it is only 1 cap different IIRC.
MAt the kit comes with washers and has german hose, if you want clear I would recommend a short piece for testing purposes.
I just pop tested 24 new injectors and they have some range, 1700 to 1900. They will be within 50 psi per set when shipped.
Chevyboy_0
Mr.SunnyDisposition
Livermore, Ca
Thanks russ, btw I'm not sure if you've mentioned it or not, but are you offering just the return kit? I'm curious because I'm about to do head gaskets and the rubber lines on this thing are crap
typ4
Newberg,OR
Sure I will offer anything needed if possible.;Sweet
I have one set left to go before the next order, all set at 1800psi with an early return kit.
For those who already have them please let me know how they work out.
thanks
