injector pump
m8094538
fremont ca
i was wondering if you guys could tell me where to find a good rebuilt injector pump for my 86. i finally got some cash together so im in the market and need to get my truck back on the road soon. found a few on ebay but ive heard they just replace the one thing that wore out and slap it back together and as this is my only form of transportation i dont wanna deal with getting an unreliable pump. thanks in advance
MUDKICKR
NITRO WV 25143
you will find out that you get what you pay for. if it was me, i would get ahold of mel and get a jr moose pump, unless you have a turbo, then id get the reg. moose pump. his screen name in "AGNEM" just pm him and see what it will take.
93iditurbo
victoria b.c
if u have the money i would definetly go for a moose pump, but if your like me and cant afford one, Pennsicola Diesel.com has a pretty cheap rebuild pump.
BrandonMag
Dana 50 rebuilder
Oregon east
Slade
Roseville CA
I'm running Mel's Baby Moose rebuild on my '94 turbo and it's plenty big enough with BB injectors. It will save you some money over his high performance pumps.
m8094538, fnally got a chance to answer your PM.
m8094538
fremont ca
so i ordered my pump last night and i just wanted to thank everyone for the quick replys. i decided to just go with one from pennsicola for now being as i couldnt afford the moose right now, but they didnt need mine as a core so in a few months after i get my bills caught up and some cash back in the bank im gonna send mine out to mel and get the injectors too. i know this'll cost more in the end but right now money is tight and i need the truck asap.
m8094538
fremont ca
Yea I'm praying I get a good pump. Like I said I only really need six months out of it and ill be upgrading to a moose pump. Now the fun part is gonna be trying to change the
pump I have. Never done it before and I'm just hoping it goes smoother than when I put my injectors in, took me three days to get them to quit leaking
itsacrazyasian
residentcrazyasian
boca raton, fl
I personally think the pump is easy to do on these trucks. the GM diesels are a pita. especially since you need a scanner to time the thing.
friend of mine had a 6.5 diesel, 3 pumps later from Pensacola.
when i needed a pump for my Suburban, i bought it from the dealer, they had the best price on a new pump. Weird huh!
vegas39
las vegas, nv
There is also a place in Arizona that has reasonable deals on our pumps, seen them on ebay a few times.
Michael Fowler
Bel Air, MD
Changing the pump is not difficult, unless you make it so.
READ READ READ everything you can find in the tech section before you do anything.
DO NOT REMOVE THE PUMP ATTACHED TO THE SEMI-CIRCULAR COVER ON TOP OF THE ENGINE!!!!
First time I swapped IPs, I think it took about 2-3 hours. Second time it was less than an hour.
Read the tech articles before removing anything!
vegas39
las vegas, nv
Some people like to remove the lines while the pump is on the truck, I find it easier to lift everything out as one piece.
Only problem I found, is the clearence is tight trying to move the pump back far enough to get it out. I solved this by pulling the pump back a little and removing the top pump mounting stud, it gives just enough room to pull it out.
Dont stress, it really is an easy job.
seawalkersee
It needs a turbo...
KCMO
I pulled the inlet line and did it in about an hour and a half.
SWS
