Idle rpm ?
idipwr
Ohio
What should our trucks idle at? 650rpm iirc? my 94 is at 750-800 by the tac. Seems too high, but it wont adjust any lower.
93_444idi
first on race day
missouri
with a moose pump and bb injectors you're putting more fuel in at idle. so your idle goes up. i idle about 800-850 with my maxed out pump.
phazertwo
Die Summer DIE!
Crawlorado!
I have a similar problem. When the truck is cool (right after the high idle kicks off) it idles around 650, but after it warms up good it moves up to 800-850. I just assumed it was the new IP, and injectors.
PZ
My Moose pump will idle any place I want it to. If when you are trying to turn down the idle and it wont drop any. Look at the cold advance piston contact. That may be a reason the rpm wont drop when you turn down the idle. I maintin a gap between the cold advance piston and the throttle lever. Its only about 40 thousands but its a gap none the less. If yours is still touching when the engine is warmed up a 1/4 inch socket on the piston head will lower it setting easily.
tke395
