IDI Sled Pulls
Dieselcrawler
Professional wrench holder
Quakertown Pa
probly why i broke mine brad. i ran 18 in the steers, 5 in the rears. had plenty of bite. lol
i plan on pulling mine again, but i will be exibition only wherever i go. but that will have to wait till it is back together.
smokin90
winchester,va
anyone have any tips on tire pressure? i had a few people tell me run around 18psi so the tires will spin a little, and i had other say lower the better? :confused: last time i tried second gear but i thought i was going to smoke the clutch, so i restarted in first and just gave it to her! any other tips?
for a stock truck i wouldnt run less then 20psi in the front no less then 35psi in the back the more you take out the more the tires are going to bite and if you go to low its going to bounce the sled ways around 50,000Lbs my buddy and me always used 15 and 35 that always worked for us
88beast
pa
the gf wanted me to pull at the lebanon fair this year but i said not till i fix a few things and do some motor work but well see if she can talk me into it by the end of the year
BP6.9
covington, TN.
naw haha i pull alot of goosenecks with it and alot of freinds wanna see it in a truck pull, im still undecided thow
hogfmr88
What has everyone been getting for distances? I pulled my old "Ox" in 08 with Firestone transforce and about 1200lbs of weight. It went 169'. In 2010, without any regard for the truck, I pulled 190. That time it had bfg at kos and about 200lbs weight.
Dieselcrawler
Quakertown Pa
i made it 149 when the rear shaft let go. but was still cruising along good. vid is on utube
Diesel_brad
Dunce
gilbert pa
Distances have really nothing to do with it. It all depends on the overall track length and how far the sled operator wants to let you go. In all reality, he could just hold you at the start line and not let you move an inch.
RANOVRU
Virginia
89ford
Pierce City, MO
I pull with mine NA alot its getting ready for a turbo but I get about 190 every time and I pull about 4 times a year
Jake_IN
West Lafayette IN
Nice! Thats the kind of stuff Im looking for.
Do you remember what gear your E4OD was in??
First video from two years ago was 4lo second gear and i couldn't get past 2200 RPM's with foot floored and barely a wisp of smoke. Second video is 4lo first gear, floored, injectors with less than 2000 miles on them and i advanced the pump a little bit. Was against the governor most the time as you can hear in the video (cackle goes away when I'm against the governor then at the very end it comes back)
Jake_IN
West Lafayette IN
MadScientist
