IDI/PSD gauges
robmoore11
surrey bc
i was wondering what gauges and pillar mounts you guys recommend? and where to order from online. and also do gauges that you would use on an idi work on a powerstroke? because when i upgrade trucks im wanting to go to a early PSD so i can stay with the same body style. i love the turn out windows.
94f450sd
somewhere,ma
the gauges will work on any diesel you want to use them on.only difference you will have between trucks is the pillar pod itself is different between the 87-91 and 92-97
oldblue05
PIN IT TO WIN IT!!!
Caldwell, Tx
I utilize the cheap ass gauges on ebay, glowshift is alright, about half the price of autometer units....
Diesel_brad
Dunce
gilbert pa
I recommend ISSPRO or Autometer gauges. You will be saving NOTHING by buying a cheap gauge, when it goes bad or is inaccurate.
I also recommend a 1600* EGT gauge and at least a 30psi boost gauge if you plan on a powerstroke swap
robmoore11
surrey bc
That is what I was thinking. What is the max boost of a 96 psd?
robmoore11
surrey bc
is there anyway to fit a 3 pillar pod for a 92-97 f250 onto my 1990 f250, they dont sell 3 gauge pods for the glowshift gauges for my 90.
robmoore11
surrey bc
YOu can get a 4 pod one I'm not sure what years but I bet a little cutting and you will be set.
i decided to get a triple gauge pod dash mount. and then once i add on my turbo im going to get a boost and fuel pressure gauge to add to the collection. single swivel mounts on each side of the triple.
snaponprofile
NY
It seems that everyone who bashes glowshifts don't have them - Kinda like the E4OD haters. Glowshifts are great gauges. The only ones I've read that go bad are fuel pressure.
robmoore11
surrey bc
where do you usually install the pyro? can i install after the 4 tubes merge into the 1?
snaponprofile
NY
Cylinder #8 or the crossover 4 inches away from the manifold (like I did).
