how accurate are digital pyrometers?
93f250idi
strokin
cadiz ky
im looking at buying this pyro. wondering if they are as accurate as a manual gauge. thanks! ;Sweet
rjjp
Needs to go test
Clare, Mi
That will play hell with your eyes, should be alright for accuracy, but will probably lag a bit, and have you tried to read a digital gauge while it's moving, such as a digital speedo or tach?
93f250idi
strokin
cadiz ky
no i havnt just thought it would be cool. guess ill stick to the old style mechanical guages.
jonathan
sullivan In
i agree with all the post. it would be hard to read when the numbers are going up fast. i rode my friends motorcycle and it has a digital speedo and it was hard to read
smolkin
Stuck inside Mobile
Mobile, AL
I've been thinking about a digital one also. To those who have a pyro: would the temp on a N/A engine actually climb quick enough to make a digi unusable? I rarely tow and there's like 3 hills here.
sle2115
NRA LIFE MEMBER
Southeast Ohio
I have a water temp, oil pressure, voltage in digital and never had a problem reading any of them. If I find a pyro and boost gauge that matches, I'll be installing them as well. Just want a quality gauge, mine are VDO and seem to be pretty good after 5 years or so.
93_444idi
first on race day
missouri
i have a digital pyro and mechanical oil temp and boost. crazy right. but i rode in a guys dmax with a digital pyro/boost gauge and i thought it was cool so I got one. I think its easy to look at.
I would think a digital would have an advantage over a mechanical. Who cares how fast the numbers climb, ya don't watch it that close anyhow, it's the top end that your interested in and at nite it would be easier to see. If you get it, just don't cut the wire to length, they are calibrated to the resistance of the wire length. As far as accuracy goes, it's where the probe is placed, in the exhaust manifold at #8 cyl. is best.
A digital will give you degree by degree readout, whereas a mechanical you are kind of guessing where the needle is.
FORDF250HDXLT
Maine & Oklahoma
i have digital gauges.
they are very easy to read.not ******* the eyes at all.
mine do not lag at all.very fast and accurate real time gauges.
some of the comments here about them are from people who don't have them im guessing because their results sure do not match mine.
93f250idi
strokin
cadiz ky
thanks. what brand do you have?
