I need some help pleaseeeeeeee
foxracer5464
deleon springs,florida
Well I recently picked up a 85 f250 with the 6.9 it ran ok first few dAys I had it then it started missing had a lack of power and there was a weird noise coming from the intake I took an inferred thermometer to the exhaust manifolds and discover that two of the cylinders were colder than the rest so I went to the junk yard to pick up some injectors just to try them out I replaced the two injectors and also did a return line kit and nothing changed possibly got worse so I went back to the junk yard and pulled the injection pump and swapped it out and now it doesn't even start it doesn't get any kinda fuel out of the pump i know my lift Pump is good but I don't know what else to try I'm really starting to loose hope I mean I know there is a good chance that the PumP I got from the junk yard is bad but I would think it would still spit a little fuel I don't even get a droP out of it
gonecrazyi
florida
We need to find a time for me to head over there and take a look it. Sounds like you just have had bad luck with ip's. Im sure we could get her running if there's no immediate motor issue. But no matter what it is I have the parts to put anything back together.
foxracer5464
so do you live on corrall ?? and i work at auto zone on providence so if anything i could always come out after work also the truck is at my parents house cuz thats where all my tools are at the moment but i live in deleon springs
Small world down in florida...:D Hopefully this starting issue is something simple like a wire not really connected on the pump for power. As for actually seeing fuel come out the injector lines.. Nope.. You will not see that. At cranking speeds almost nothing is dripping out the lines. These engines drink very small amounts of fuel during cranking and idle settings. Thats why we recommend to hold the throttle wide open when bleeding air and fuel from the system. Its pushes more fuel per rpm at cranking speeds.
gonecrazyi
florida
It is a small world. I go to that store all the time. Probably know us by face if I saw ya.
gonecrazyi
florida
Im generally off monday and Wednesday but have to work tomorrow after class. I could probably swing by around 130. Ill probably be driving my truck so you cant miss me,
