Ok, so if its a 93 7.3 with a turbo is it the one with the factory turbo? If so the first thing that needs to happen is he needs an upgraded downpipe. Ford flattened these on the ATS/Garret factory turbo systems. the bad news is that it will also require cutting or bending a bit of the firewall away to make the "real" downpipe clear. Safe boost? You can go as high as probably 12-13psi on a factory turbo engine with stock bolts and heads. ANy more than that and you need new gaskets and head studs. Hopefully he's already got a pyrometer and boost gauge. Beyond that you can try the basics...bigger exhaust, better air intake, water/**** injection. You can take it a long way. Another thing, you can buy a turbo cal. injection pump from Ken @DPS or from Hypermax. The thing is he needs to be reasonable in his power expectations. It isn't a PSD or a Cummins. You won't be making that kind of HP without modifying it to the point that it really isn't streetable, and even then its a tossup. My advice, make the turbo breathe well, give it as much fuel as you can handle adn keep the pre turbo EGTs under 1150 and live with what it is or tell him buy a Cummins or PSD if he wants the 400-500HP stuff
