It's not a turbo, or a complete turbo by any means. But what it IS, is all the stuff short of some pipe, that you would have to fabricate to mount a turbo.
you get a mounting bracket, a downpipe, an exhaust housing, a gasket, and a brand new exhaust pipe tail extension (not pictured) and clamp (which positions the downpipe to be readily connected to your existing exhaust). All you need to do is add a center cartridge, a compressor, intake hat and boot, and all the up pipe you can fab up. I'm asking $75. I can assure you there is at least $300 worth of parts here. Hypermax is very proud of their down pipe which sells for $127 alone. This is made to fit an automatic, but could be made to work with a manual if you fab your own pipe. If you want to buy the rest of the parts from Hypermax, they are all still available.
All parts are solid, with surface rust only. you will need to spend some time removing the burned off bolts from the exhaust housing (I was in a hurry. Sorry).
The bracket mounts to the back side of the passenger side head.
