Hydroboost on older than OBS trucks
lotzagoodstuff
Carmel, IN
So I have a new in box hydroboost for an OBS Superduty that another member is interested in. My question is in regards to bricknose and older compatibility.
All you hydroboost users out there: got any experience or input?
As always: thanks and Merry Christmas
DesertBen44
Grand Junction, CO
From what I understand (research not personal experience) The hydroboost is bolt on for the OBS< for the brick and 80-86 you will require additional parts, aka the pedal assembly from a superduty
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
mine bolted right into my 86. even the cast iron master bolts right to it. some have issues with the pin postition on the pedal. i didnt, my brakes work great!
idiabuse
Princeton Fl
I did it to my 1988 F250 super easy.
The pedal had to be removed and modified.
I pushed out the pin welded up the hole.
Made a new hole about an inch higher and pushed the pin in.
Welded that up too.
Now I dont get tired from doing pull ups on the steering wheel just to get the truck stopped anymore.
No more panic stops.
Much safer way to go than a booster.
Javier
I used all new ford parts ordered for an 89' F-450 superduty on my 83 with no problems.
88beast
pa
mine bolted up (88 cab) and fit well i used the fsd mc also and it works great
Bo17
