geonc
SPIDER BAIT
I seem to have found one out of an '90 F-450..complete w / NEW high press hoses and resivour for a duce
Also if my fogged memory serves, isn't the F-450 master cyl the most desired due to the 1 1/4" bore?
I read Full Monte's article and the only thing missing is the connection for the elec motor...{blue cyl in pic}..in event of eng failure, pressing the brake pedal energises the motor for braking assist. {or so I recall}
Is any modification to the porporting {sp} valve required for rear dics :Sly
While there, they were stripping out a '04 E-350 cargo van that was wacked in the front/right side and I beleieve they will sell me the disc setup...lines/ parking brake cables, rotors/calipers.... the whole mess!
It has the Sterling rear so mods if any to the brkts should be minimal
Those calipers are about as big as the fronts
It's great to be able to mod the OBS chassis regardless of IDI or PSD
