So before assembling the dash and all that in my truck I visuall chcked every connector an put some vaseline on the vacuum connections. Now I go to pull a vacuum on the main black hose that is nromally hooked up to the T block on firewall..I cant get any vacuum. Constantly leaking from somewhere. My default vent setting is to defrost. Also had to manually put the fresh/recirc door to recirc since the vac solenoid dont get no vacuum!.
I will assume that by trying to draw a vacuum on the main black hose (there is a white and black one that come thru with the blower fan electrical wiring) i should be able to pull a stable vacuum down yes?
