genscripter
I've already sized my top and 2nd piston rings ok. I'm working on the oil rings, and unlike most of the oil-ring tutorials on the net, the IDI oil-ring setup is different. It has a concentric wire inside the coil, that it surrounded by a ring housing.
I can grind the ring housing no problem down to the spec. But I'm just wondering about the inner coil? Can I pull out the concentric wire, then grind the coil down a few ten-thousandths? But unlike the outer housing, I can't get a really exact measurement in the bore to find the gap.
I bought oversized rings so that I could grind them to the exact min spec. Everything is good, except on how to grind or resize the coil inside the oil-ring assy. I bought 030 over my size (limitations on what was sold.... I had to choose from Standard or 030 and nothing in between). I originally bought Standard as per the cylinder skirt spec dims, but when they arrived, they were already above the max piston ring gap spec. So I'm using these oversized ones, and gapping them accordingly. Any advice would really help me out. I know the coil expands and shrinks in the groove, but I would think a ring that is designed for 030 over would be too large for the compression to handle. I'd say it would need to be ground down at least some point. But how do I measure the gap on this wiggly oil ring coil?
