How To Post Pictures
My motor buildup is coming along slowly but its getting done. I have some pictures I want to post here but can't find a section of how to... Any help will be nice and I'll post pictures so all can see whats going on in my driveway.
dbarilow
over worked
Abingdon MD
[size=+1]You could upload your pics to Web Shots
Or Photo Bucket
Then use the "IMG" tag and link to the page EG:
[/size]
HTML:
[ATTACH=full]73634[/ATTACH]
[size=+1]
looks like this
Just make sure to resize the pics[/size]
rubberfish
Langley B.C.
Click "post reply" not the quick reply box.
Type your text, scroll down to " additional options"
Where it says attach files, click " manage attachments"
then "browse" then select from file your machine and click "open"
then click "upload" and at the end select "submit reply"
and when your done it will post like this pic
gandalf
Senior Member
CA &/or Maine
Test
This sounds too easy. Hope it works. The only drawback I can see so far is file size. But I'll give it a shot. This was taken 10/2005. Thats the truck waiting patiently for a new engine.
On Edit
First time didn't work. Is there a size limit on the images? Trying again.
Edit Again
Cut picture size in half.
Mike
Stroker
Cora
Yeah, you should be able to upload a jpeg or jpg that is upto 999K.
seanpistol
southern california
any web adress that ends in .jpg, .bmp, .gif, or any other picture format can be posted with the
tags. to get your pictures to end in .jpg, upload them to photobucket, webshots or a similar site. you can right click on a picture, select properties, and copy the adress of the picture if you find something on a random website you want to post. just type
and it'll work.
for example, i'll post Agnems icon.
hope that made sense...
Well, If I have done the correct things you may see some long awaited pictures of my motor buildup. Here's hoping it worked.
The promised pics...
So, if I have done things correct this may be the pics.
Crap... Things are not working here... Sorry guys I will fugure it out later when someone can help me on this end. My daughter is really quick on these darn computors. I really am not the brightest candle on these things... :cry: -Lame -Deadhorse
Pictures Finally
Here are the pictures of my engine rebuild....My daughter helped me post the pics.. The pic on the left shows the spare injection pump inplace for gear coutinuity. The pic on the right shows the bare block and on the # 5 cylinder at the bottom you can see the chip the broken rod did. I really tried to highlite the crank line bore work but it didn't show up too well. The chipped liner shows up on #5 if you enlarge the pic on the right really well.
