I read about pulse method timing in the tech threads, but have no idea where to find a shop in Omaha that does it. Will I have to go to Ford garage for this procedure? Out of curiosity, and I won't go crazy trying to time by ear because I can't afford a catastrophe, do you rotate the pump clockwise or counter-clockwise for advance/retard. Do I want to get baseline pyro measurements prior to any adjustment?
Now I don't want to pretend that I know anything, and don't jump on me for admitting this, but I have never owned an induction timing light, and I have timed all of my distributor gas motors by ear. Can you apply similar techniques here, or is that asking for serious trouble. I'm no idiot, but like many, trial and error is hard to resist and, sometimes, a hard way to learn.
What this site has to offer is a life saver!
Chances are if you go to a ford garage, they will charge you $150, and then THEY will time it by ear, because they sold their IDI timing equipment out of their tool crib a few years ago. The dealerships are not required to support any vehicles past 10 years and after that they sell off the special tools that go with them, if they didn't they wouldn't be able to get into the tool crib.
Any shop you call that tells you over the phone that they have equipment to time a diesel is going to assume you mean PSD and when you get there and they can't find a computer port, will time it by ear and charge you $150. After either of these events and you wonder a few months later why you keep eating glow plugs, you would have been better off in th efirst place to do it yourself.
With a regular inductive automotive advance type timing light and a Ferret You can easily time the thing yourself, and then you have the tool for the next time you need to disturb the pump for any reason It pays for itself very quickly. Even if a shop had the right equipment, they could officially *time the thing* by hooking it up and if they checked it and it was at 6.5 deg btdc, they could call it good. The factory spec was 8.5 deg +or- 2 deg meaning if it checks anywhere between 6.5 and 10.5 they can check it and call it good, but if you ever tried to pull a load over a hill at 6.5, especially with the new ULSD fuel, you would know that is completely unacceptable, but noone working on a flatrate is going to spend the time to get it exact like it needs to be especially since the timing has a nasty habit of shifting a hair when you tighten the pump all the way down. As in most things, you are best off doing it yourself., or if you just happen to be coming down through central Arkansas any time soon, you're welcome to drop by and we can time it up here, but that's a little bit out of the way I imagine.
