>> HOLLEY RED/BLUE ORIENTATION ??
MIDNIGHT RIDER
When mounting a Holley electric pump, must the motor be above the pump, or the pump above the motor, or does it matter ??
I just had reason to mount a Holley RED on an old gas-burner in order to be able to move it around in preparation for a diesel swap.
I went ahead and mounted it with the motor on top; but, in order to do so, I had to "horse-shoe" the fuel-lines going in and out by using two street-ells on each side.
I could have put the motor on bottom and then went straight in/out with the lines.
The CARTER standby/bypass electric pump on my Ford/Cummins specifies it be mounted motor down, as the fuel cools the motor, but it seems I read somewhere that the Holleys had to be mounted motor up.:dunno
Thanks.;Really
RLDSL
Diesel fuel abuser
Arkansas
The motor chamber on the holley pump is a dry chamber and it prefers to stay that way, Motor up ;Sweet
MIDNIGHT RIDER
Thank you, sir.
I got to puzzling on the situation and I ?think? maybe I could have simply loosened the motor-clamp and turned the whole thing 180*, thus eliminating the need of all that extra plumbing.
There is a sort of protusion on the side of the pump that is currently facing outward, which would face inward when rotated.
I will get out one of my swap-meet collection of Holley REDs/BLUEs, loosen the clamp, and see if this rotating theory will work.
If that protuding business interferes with mounting, a smart man like me can simply add a spacer behind.
Why didn't all of this come to me before I screwed on all those elbows ??cookooLOL
RLDSL
Diesel fuel abuser
Arkansas
If you have to start fabricating a new bracket, run down to your friendly neighborhood scrap metal yard. You can find nice big chunks of scrap aluminum angle, about 1/2" thick that is perfect for pump brackets that is real forgiving for squirrily cutting to fit into odd places and is very strong , probably end up costing you about $2 ;Sweet
Staff online
