heres an interesting question...
turbonator
gm diesel guys, AKA turbonator
canada
are the gm 6.2l/6.5l pre-combustion cups the same size as the 6.9l/7.3.....:dunno
turbonator
canada
are the gm 6.2l/6.5l pre-combustion the same size as the 6.9l/7.3.....:dunno
i know that it was recardo that designed this style chamber, but i am not sure if the pre-cups were the same dimensions between the different engines.... if they are you 6.9/7.3 idi guys might see a huge improvement by using a set of late model 6.5l diamond pre-cups which were available only in 1996-to present... they have a larger "mouth" and are machined down inside to give the 6.5l a comp ratio of 20:5:1....
Might be something we should be looking into. Maybe this is a question that towcat could answer....:dunno My first set of ported heads had plenty of work done to the precups throats. I may have done too much cleaning up to them...:dunno
turbonator
canada
We have a 6.9L here, that we were thinking of scrapping, I will pull a head and verify the pre-cup dimensioning and post up later.
The 6.9 and 7.3 cups are the same. The chevy 6.2 or 6.5 cups are whats getting the interest here...
turbonator
canada
what i am wondering is if the pre-cups are the same dimensions to swap from motor to motor...(6.9 to 6.5 or vice-versa)
turbonator
canada
If you don't get around to it I can take some measurements on the 6.9 here at school that's torn down.
thats a good idea, measure the external outside diameter at the top, and the external out side diameter at the bottom, height, if you want to really impress, do a volumetric measurement, and we will do the same here with a 6.5l turbo pre-cup...;Sweet
flareside_thun
Reviving The General Tao
Tavares, Florida
I'll see what I can do.....It's my baby for the school to sell and buy another engine to rebuild....I love doin this every once in awhile but couldn't do this all the time.
I have an easy to examine precup in the "cutaway head" that everyone who has been to an IDI Weekend has seen.
Black dawg
sw mt
6.5 precup
od at head surface 1.561
od inside the head 1.356
thickness of deck surface of precup.1875
overall thickness height of prechamber .855
tke395
