steelheadguy
Registered Idiot
86 with T19 4 speed
Clutch pedal and fork do not move, pedal is completely stiff. Forcing it broke the push rod, but has been replaced.
There are ball bearings visible through the window under the flywheel.
I do not know much about transmissions, but Im guessing the throwout bearing is bad. I am preparing to lower the transmission to replace the throwout bearing along with pressure plate and clutch plate. I was also told to resurface the flywheel.
or could it be something easier? With just the fork?
I am very grateful to anyone who replies to this thread. It will be full of almost clueless question from me so I am organizing them. Feel free to answer one or all!
1.Where do I begin to lower the transmission?
2. Do I need to disconnect the transfer case?
3. Do I need to remove the starter?
4. Do I drain the oil?
5. Is there anything else I should do while here?
