Help Using my new Ferret
mankypro
Learning Slowly...
Boulder County, Colorado
So I go tmy Ferret today and the instructions say:
"Pulse injection timing readings will generally be before TDC and 7 to 10 degrees before luminosity timing readings"
So I've read that what I want is 8.5 degrees BTDC, do I have to modify that to use this pulse detector?
HammerDown
Glenolden Pa
Beats me but when you figure it out and you're done with it mail it to me so I can use it...of course I'll pay shipping ;Sweet
77f250diesel
Florida
I set my timing lite to 8.5. There is no offset using the pulse adapter.
Dennis
RLDSL
Diesel fuel abuser
Arkansas
8.5 is what you st the timing light for, don't over think the thing:D
that's if you want it right on the factory spec, if you want it to run better on the new fuel, try closer to 9.7
So help me to undrstand this timing we do. I install my dampner probe in the holes closest to the water pump. Then I adjust my snapon timing lite to whatever I want. This usually is 9.5 DBTDC and I'm using the lower hole where a probe "could" fit because it has the mark on the tab. I hope this is correct... Calvin, Is this correct or anybody else with some timing background???
