DieselChemist
When I push my clutch in the firewall moves considerably. I looked at the outside firewall and no crack. But inside the truck, above the top slave cylinder bolt, were there is a joint in the firewall, it looks kind of rusted and moves. Is this the typical firewall crack. I know you can buy two different kits, which one would I need, and what are the part numbers, I am assuming I need to get it from ford.
Thank You
Bill
Thank You
Bill
