I was given an old Karcher HOT water pressure washer....doesn't work. I was thinking of taking the coils in the heater section and running a propane burner in there and pumping Waste oils through the coils prior to centrifuging...perhaps getting upwards of 240+ degrees...
Is there a down side to heating to this level? I would think that I should be able to get any water to steam off as it goes from the the heating coils and pours into a barrel then gets pumped to centrifuge...
The burner setup currently is supposed to be fired on diesel....however that mechanism is not functioning some kind of electrical issue, and I don't know how to make it work or I would thus making use of WO to fire the heater to make WO.
I have seen barrel heaters and don't like their function they don't work as well as alleged, having much experience with them with polyester fbierglass resins in barrels heated by band heaters that just don't work well...takes a long time to bring an oil barrel of resin up any amount what so ever.
So...whats yer take gentlemen?
