No, Do not double up the gaskets!! Are you turbo-ing your engine? Is that why you are after lower compression?
With the Felpro gaskets being slightly thicker; are they less prone to future failure? Are they thick enough to drop compression at all?
I have never had a victor-reinz set in my hands so I can't coment on them
THe VR are top shelf, THey also make the factory gaskets ( and the factory gaskets for just about every high end diesel engine and gas engine manufacturer in teh world )
more thickness in a diesel would not equal extra strength with the kind of pressures involved
If you want a leak free installation, get a set of VR gaskets and shoot them down with about 3 light coats of spray hylomar on each side and carefully install. You will have a trouble free engine( at least your head gaskets ) it's an old trick we did for years on foreign diesels and now most of the fancy euro diesels come from teh factory with their HGs treated that way
Decking your heads on a diesel like this is not going to change your compression. THat only works on gas engines with domes in the cylinders heads. The valves are mounted flush with the head deck on these critters THe only recession is where teh valve themselves recess into teh seats and you are not going to gain enough there milling teh head to make a measurable difference in compression ( if you do it means your valves are sucked up WAY too far and it's time for some major surgery on those heads )
