lindstromjd
Black Sheep
Are they really worth putting in when you turbo your engine? I need to do a head gasket swap anyway, because one of my heads is toast.
Since I need new ones, I figured I'd upgrade a little and not have to worry about quality. What's the best place to get the head studs and main girdle studs?
While I'm at it... where do you get thicker head gaskets to help lower compression a little with the turbo swap?
As for a main stud girdle... No need. These bottom ends can handle way more hp and torque than we can make. BTW everything in the bottom ends are shared between the 6.9 and the 7.3 with or without a turbo. Thats a tuff bottom end.
