HARD KNOCK AFTER LIFT PUMP REPLACEMENT
Ian Rebmann
San Diego
another thought if the cam lobe is very worn and if the lift pump isnt able to push enough fuel up could it create a knock? Im thinking that the shavings in the oil filter were from the cam lobe. the lift pump looked pretty new so it was probably replaced not to long before I bought her. The wear on it the pump was not that bad and it seemed to function fine when I pulled it off. so maybe the cam lobe is more of the problem and not the pump.
Macrobb
North Idaho
There are no vacuums lines on a diesel, minus the vacuum pump itself.
The VRV for a C6 automatic requires vacuum, and this mounts to the IP throttle shaft on the driver's side of the IP.
Ian Rebmann
San Diego
OK sweet i was still a little unclear on why there was air headed to the IP
tke395
