governor spring
ken74amx
McHenry/IL
I want to turn the max rpm up on my truck. I've heard about the 6.2 spring swap. My question is where do I get this spring and which one is it in the top of the pump?
They are found in the stanadyne db2 pumps found on the 6.2 and 6.5 chevy diesel engines.
dyoung14
Is getting worn out
spencer,tn
Yes i have done it:sly very fun too:D
PM mell agne screen nam AGNEM he will sell you one that will do the trick
dyoung14
Is getting worn out
spencer,tn
http://www.youtube.com/watch?v=GaWOistOXLA
This is non turbo and the first engine,
I wish i had got one when it was turboed with the second engine, but i never really did i got some high boost videos that it was tached high in but you couldnt see the tach anyway enjoy
And that truck has a blowed head gasket now
jonathan
sullivan In
you blown another gasket? that sucks
mudduck
davenport , iowa
it took 28 psi to blow it on stock head gaskets with no studs , or were they after market with studs?
dyoung14
Is getting worn out
spencer,tn
Took 28 psi to finally blow them, they were new felpro gaskets put in back in june 2010, nothing special done to them, re-used stock headbolts torqured down to 80ftlbs in 5 steps
Bo17
