X-NRCan_IDI
Picked up a set of used mirrors for $30. The glass has some scratches and there is a bit of rust, but overall its quite tolerable in my opinion. The seller said they came off an "older model pickup," not sure what though, but I figured I can most likely make them work on my truck.
Now, here is the question... does anybody have any suggestions for covering up the factory mirror holes?
What I'm thinking of doing is making a plate with two threaded "studs" welded on it to attach the mirror brackets, and then screw the plate onto the door using the original holes/screws. I would only be using the bottom bracket on the lower part of arm of course.
At the top of the door, I'd just mark and drill the two holes and bolt it up like normal.
To finish, I'll be cleaning them up good, painting it all semi-gloss black and adding some decent convex mirrors.
Any tips, suggestions, ideas and what not for this little project are of course welcome!
Pics momentarily if I can get it to cooperate...
Some day... once I'm done with all my edumucation and making a decent wage.
