Good Zf5 rebuilder
throw out bearing or the pocket bearing? Why would the throw out bearing have anything to do with it. I put it back together after I opened it up just to make sure I could since lots of people say you can't work on a zf5 without the special jig. I'm with the people that say it is a little tedious but can be done with a ratchet strap. I should do it myself before I spend more time trying to get around it than it would take to do it
the TOB is for my personal education. I have a 6bt project of my own that the previous owner was having trouble with the OEM ford TOB being happy working on the dodge pressure plate. I got a flat faced TOB to see if it was a better match. that is all.
burt
redding,ca
Does that help? My set up is the south bend clutch set up so idk if it's relevant to your situation
thank you! mime is unknown other than I know it's oem dodge pressure plate with a ZF disc on the inside and a oem 6bt flywheel. ford/ZF has curved diaphragm fingers and dodge has the straight diaphram fingers. I got a flat faced TOB hoping it will help compatibility
morgankshaw
Sacramento, CA
i know this gets asked from time to time but most threads I find are either old or the result is not good. Anybody have a source for good zf5s. Midwest sounds good on their web sight but their reviews aren't great. Seems like every reman story I hear takes a couple tries before you get a good one which is extremely careless. I'm in Northern California and would like to find one that has a easy core exchange. The fresh reman in my truck welded the pocket bearing so that one was done wrong. Lkq I think is what I was told built that one. Thanks
I used manual transmission warehouse they are off north gate off hwy 80 in Sacramento. They were friendly and very reasonable.
burt
redding,ca
Thank you for that recommendation. Did you get a full rebuild or just a certain thing fixed there?
morgankshaw
Sacramento, CA
I had them combine two trannies I had, they used parts from both to build up one good one. Then they measured all the clearances and put it back together. Luckily I didn't need any new parts. Kept the cost then. I think he said a full rebuild with new everything is around $1200. ???
Anyway was a very helpful and friendly place. And I'll be back next time. They had at least 4-5 zf5's they were rebuilding that I saw.
Laine D
Northern California
I just picked up my zf5 from the tranny guy on Friday. http://www.elkgrovegear.com/
He does a ton of zf5’s and zf6’s, he even keeps the syncro rings I’m stock. Free inspection and a 1 year, unlimited mile warranty. He found me a new case because mine had cracked, and did a reseal and new synchros for $700. It would’ve been $400 if I didn’t get the case. Right next to Cordova truck off of happy lane in rancho Cordova. It backs up to
Mather airfield. He does it right, I will always bring him my stuff.
