EMD_DRIVER
Say what?!?!
My truck has been hard to start since I bought it. The only way to get it running is to plug it in, or give it just a whiff of ether. I know ether is BAD, but I need the truck to get to work.
I replaced the glow plug relay, when the old one fell apart. I was in the process of changing the oil pressure sending unit at the time. Since it was a new relay, I assumed that it worked and that there were one or more GP's that were bad.
I decided to check, to see how many GP's were actually bad today. All of them tested fine using a test light, so I ohm'd them out too (Just to be sure) All of them ohm'd out just fine too!
I found a post that says you can ground the terminal on the relay, with the white wire on it and it will cause the relay to engage. My truck is an 87, with the solid state controller. When I tried grounding the terminal, nothing happened.
I know I have power to the two 10ga yellow wires and power to the terminal with the red wires on it. There's just no clicking in the relay and no power to the GP's
Any other ideas?
Gary
Any other ideas?
Gary
