gear vendors overdrive
c_silva88
coventry ri
i have a a 1345 with gear vendors over/underdrive unit complete with all the wiring and every thing to install it shifts smooth looking to get $1000 obo . will trade for a complete turbo set up for a 6.9 with a zf behind it
c_silva88
coventry ri
its still in my truck im swapping in my 5 speed in this week
this GV unit will work behind any 4wd trans. all it cares is that the transfer case is ideally a BW 1356. why? the BW 1356 has a removable tailcone. if it is a BW 1345 unit, then you will need the back half case casting as shown in the pic or find your own 1356 back housing.
hope this helps clarify things.
alienturtle
Human
Ripon, CA
So it'll work on the zf 5 with the bw1356. Damn I wish I had the money !
Correct. When it comes to gear vendor units when bolted to a 4X4, The tranny does not matter. It only cares what its getting bolted to. In a 4X4 that is the T-Case. In 2wd form that is the tranny ;Sweet
sle2115
NRA LIFE MEMBER
Southeast Ohio
To the OP, I don't think that transfer case is a 1345 either, the 1345 uses the whole rear cover as the adapter for a GV unit. That looks to be a 1356 as Towcat said.
gonecrazyi
florida
Its a 1345. The case is stamped gv and the speedo cable is cast into the t case tail housing
dogdanblue
