smokin90
what gauges would you put on a 1990 f-250 na and where can you get an A piler gauge holder
What all is done to your truck, and what do you do with it. You may not need gauges
, might as well be prepared for it
You can suppliment your factory gauges. After that, pyro a must, fuel pressure, vaccuum and room for a boost gauge, turbo is always an option, might as well be prepared for it
Learning what to expect from these gauges, fuel pressure and vaccuum, will give earlier detection of a problem. Remember, vaccuum is what helps you stop unless you are hydroboosted.
....a pod over the rear view mirror with fuel pres, vac pres, eng oil temp, rear diff temp all autometer phantoms and a set of white face gauges over the stock ones, and the white over lay for the heat controls
