gauge wiring
88beast
pa
anyone got a diagram for the gauge wiring i need to splice into power for lighting, the fuel gauge wires, low fuel light, volt gauge wires, and any other warnings.
and the only hint is theres 400 in gauges on the way to my house and i have about 200 more in gauges already here.
but id like to splice in at the connector to the gauge pannel that will be easiest route to wire.
ah1988ford
florida
Why not just wire it up to the fuse box I think it would be much easyer :dunno
Poway, CA
What I did, and I'm not saying its the right way, but it worked.......
If you have an aftermarket stereo and don't use the dimmer feature (mine doesn't have one. Most don't), you'll have an extra wire hanging off the adapter harness you used to hook it into the OE wiring harness. Of course, that assumes you used an adapter. Anywho, I just hooked mine up to that wire. Super easy since the gauges are hanging under the ashtray. Works great!
Mike
88beast
pa
ok ki gotta let the cat outta the bag. those stock gauges are going and yes i can hook in power no problems but, my new cluster will have aftermarket cauges that need hooked up. that is why i need the wiring diagram. without it i got to poke around for wires to find stuff like fuel level wire and other things.
smolkin
Stuck inside Mobile
Mobile, AL
This is what I have, not sure what years this applies to, but it's accurate for my '90:
88beast
pa
thanks thatll help i was hoping for a pin out lol
88beast
pa
o ill be uploading tons of pics but the gauges are being custom made so itll be a bit till i get them
88beast
pa
im putting them in but they will be coming from speed hut and i already got a lot of autometer gauges
also i replaced the mat on the floor today and am uploading pics now
88beast
pa
ok quick write up of the mat replacement
first out with the seats and the mat
then lay new padding
and i put the old mat under for extra sound deadening
here is how bad it was
view of new floor
and the seat reinforcement bracket now they dont move at all the floor moves more than they do
i also made an audi look like crap
88beast
pa
i need some long selftappers for the shifter boot and high beam switch then its set
i also need to put lock nuts on some of the bolts i forgot them
and i got a ton of wiring to do still
then i need to get a new brake light switch cause it dont fit with the hydroboost
Staff online
