Fuel tank connection seals
Macrobb
North Idaho
On my trucks, there is an O-ring sealed connection between the plastic fuel line and the tank sending unit.
The plastic fuel line piece just slides over the steel "nipple" at the end of each line coming out of the sending unit, and then a retainer is added to keep it in place.
I'm a little concerned about the o-ring/seal in that plastic piece.
Is it possible to replace this?
Or, is there some other better way, hopefully something better than just whacking the end off and using a bit of rubber fuel line to connect the two.
Thoughts?
I've replaced them. Think it's in my thread here in the PSD section.
You can also just get the new nipple.
Shawn MacAnanny
Delaware
You can get new an fittings for them, or barb fittings to connect hose. One is 5/16 the other 3/8 I believe. I actually removed them and just ran rubber diesel rated hose to the metal nipples with double clamps. Never had an air intrusion issue. I saw them as air leak risk when I replaced the tanks.
I think of it was going to run an, I would just sump it.
Do it right the first time. Lol
JU57US
