Fuel Tank Breather Modification
When it clicks off. Remember I use the slowest setting, I can fit another 5 (FIVE) gallons in there right up to the rim.
No way diesel expands that much. Wonder if they used the same fuel tanks for gas or diesel and just changed the senders….
It's the foam from the diesel running into the tank. When the bubbles go away, then you can put more fuel into your tank.
Cant Write
Placerville CO
Yes, it shuts off on foam. And then I have to slowly put in the 5 gallons where I can watch the foam roll within fill tube. Most people don’t have enough patience to do the last 5 gallons. I know my wife gets annoyed at me :rotflmao But that’s an additional 75-100 miles of driving which matters on roadtrips
My point was that many people modify the factory fill to get fuel in faster and deal with the foam. My TDI has a “ventecomy” performed to it for this very reason.
Clb
Another old truck
nannyfornia
Ford "HAD" a better idea....
Fueling @ full bore without foam.......
Priceless
Brought to you by the idi owners of America and the internet.
The beginning of this thread back in Feb 2012, the kid
6 Nebraska IDIs shows using that clear plastic hose.
That stuff gets hard from the fuel, and will eventually have a leak problem.
Then in post#10
"I went to a station that has been well known to use gas pumps to pump diesel (this causes the fuel to foam more) so basically you are pumping foam and not fuel. Most stations around here use this trick to con you into thinking you're pumping more measured fuel into your tank where in fact its just foam."
I never heard of a station pumping just Foam.
Yeah Diesel will foam up, but it dies down quickly, just the nature of the stuff.
I have owned a Diesel vehicle since 81, drove all kinds of Diesel equipment, so I have fill up a lot of them.
This 86 F-250 I drive as a DD, the last 3 gallons was always a pain to fill. Someone will throw in here, when it clicks off, just stop, that`s where it is filled and for expansion.
I always fill to the tippy top, and drive off, never had an expansion problem or leakage on the ground.
When I installed the 38 Gal tank, installed a new Roll Over Grommet so I had good fresh rubber. Screw in a threaded/barb elbo fitting.
Then at the top on the side of the Filler Tube, drilled a hole, then enlarged it just enough so a threaded/barb Brass fitting would just catch the opening and thread in.
Be sure to rough up the metal around the hole, and throw on some JB Weld. Then connect a vent hose to both fittings. (Do not use Heater Hose). Purges the air as fast as the fuel goes in.
Fills fast and has worked great.
EDIT:
I used 3/4" hose, 1/2" would probably work also.
Air is coming out the Fill Tube as well as the new vent Hose.
Some of the trucks (I have an 86) have the vent tube inside the Full tube as I have read. Maybe the newer trucks? IDK. I didn`t have that to remove.
Vents are important as is this controlled experiment.
Oiler
