pybyr
As I plan out my total replacement of all the rubber fuel supply and return lines in the front of the truck, I have a question-
the 3/8 inch line that goes from the rear driver's side of the engine to the nylon return line [along the frame] to the tank is only press-fit over the nylon line- no clamp, no fitting. And it's barely a press-fit- mostly because the hose is so old it has lost its tension.
What should be there at that joint between the rubber hose and the nylon line?
Thanks
Thanks
