Fuel pump Removal
Iowa 73
FNM
IA
Pull the vacuum pump off and you will have plenty of room.
Kevin 007
Full-floater
Nelson BC Canada
Yes, remove the vaccum pump, the rear bolt of the lift pump can be done by "feel" no problem. Just make sure you put the pump (arm) in correctly
chevytaHOE5674
Ontonagon, Mi
I too used a deep socket without an extension. Can't see it but can get a finger on it to get the socket on there and started.
Back in was easy for me since I put a block off plate in there with an electric fuel pump, makes for easy access.
SkipBurney
Statesboro Georgia
Got it finished up today I removed the vacum pump pulled the fuel pump, installed the block off plate and finished up in just a few minutes. I thought pulling the vacum pump was a bigger deal than it actually was.
