JPF3205: Nobody has yet mentioned errors in the MPG checking. Have you made any changes in tire size? Any such changes would effect your odometer. Taller tires will cause your odometer to read fewer miles than actually travelled so your calculation will show lower mpg than actual. Also bigger/wider and especially more aggressive tires will cut into mpg (2.4 mpg on my gas truck... carefully measured)
Say you went an indicated 165 miles on 15 gallons... that would be 11 mpg. Lets say your odo was 10 percent low. The real miles travelled was 181.5 miles and your actual mileage was 12.1.
If in doubt finding a straight stretch of road with mile markers and spot check your odometer. If it reads .9 travelled over a measured mile, for example, then you know your speedo is 10 percent off. When I got my '86 in '87, my truck with 4.10s was 10 percent off with the stock 235/85R16E tires (31.7 dia) but in the other direction! I was showing more miles travelled than actual so I really crowed about getting 18-19 mpg. Oddly, going to 285/75R16 tires ("33" 32.8 dia) put the odo dead-nuts on and I started reading 16-17 or so. Then I went to more aggressive tires and 16 was about as good as it got... and again, that very careful checking.
The other thing that caused me to read higher mpg than actual was foamy fuel, which cuts the nozzle off early. To be really accurate, you have to dribble the last 2-3 gallons in.
When my truck was brand new, it's mpg was seldom better than 16 mpg at 55-60. I picked up about 1.5 mpg when I added the Banks turbo. Today, on a good day, I get 15. but in my normal "cycle" 14.5 is about it and my injectors and pump are top notch. Less in winter (1.5-2 mpg) because of the blended fuel and the longer warmups)
