fuel line fittings
6.9poweredscout
Bleeds IH red...
Northeastern Pa
has anyone here modified their fuel lines to "delete" the square o rings? i'd like a regular 3/8" flare fitting or a 3/8" hose barb fitting for my fuel filter and the injection pump inlet, has anyone done this? if so what are you using? i'm doing the fuel system on the scout this week and forgot the post that was up about this. hopefully i'll hear her run by the weekend...... ;Sweet:sly
-Jon
tractorman86
Buckeye, AZ
yea i built one for me and IIRC DIESEL JD, 3/8 gates hydraulic hose with 3/8 JIC fittings on either end and the adapter fittings and viton o-rings to put it all go togather. it worked out quite well, i've been running it for about a year now without any problems
6.9poweredscout
Bleeds IH red...
Northeastern Pa
pics, part #'s?
-Jon
Diesel JD
Gainesville, FL
All I can say is tractorman86 does fantastic work, it bolted on and doesn't leak and I trust it much more than the factory rubber doughnut gasket, oh and his price was very fair compared to IH and Ford.
tractorman86
Buckeye, AZ
i dont remember the part #s but i can send you one just pm me
here is a thread i started when i sold the one to diesel jd
6.9poweredscout
Bleeds IH red...
Northeastern Pa
im mounting my filters on the firewall....that probably won't reach. :dunno will i be able to use regular fittings on the fuel filter end?
-Jon
6.9poweredscout
Bleeds IH red...
Northeastern Pa
awsome! ;Sweet i'll mock it up and get back to you. is the inlet on the fuel filter a regular thread? and what can i use for a "bleeder" the 6.9 filterhead i have never had one. :dunno
-Jon
tractorman86
Buckeye, AZ
well they are suposed to have a separate outlet for the bleader. the threads are 1/4 national pipe thread
6.9poweredscout
Bleeds IH red...
Northeastern Pa
oh ok it's a regular thread then, for some reason i thought it was different. what's the fitting in the pump? what should i use for a bleeder valve?:dunno
-Jon
LCAM-01XA
my very own hell
Do you have any junkyards near you? You can grab a bleeder valve off a truck in there. Or maybe a dealer will have one? The fitting on the injection pump I have no idea what it is, Jake will have to chime in with that info.
