fuel leak......
geonc
SPIDER BAIT
NECKVILLE North Carolina
With the tranny out -cuss I have noticed some damp fuel near the back of the eng......area around the filter is dry....
SO....poss lift pump, or what appears to be a "banjo" style fitting at the rear of the pump.
Ramprat
Inside your OODA
Crap.....
Look at it this way, ya never would have noticed it if not for the clutch going out :eek: :rolleyes: :D :D
THink silver lining :angel: :angel:
sassyrel
iowa
could be either-george--when clutch back together--may have to use flashlight and mirror to pinpoint area of leak---on mine the fuel pump diaphragm died--and thought it was something in the injectors---so check minor things first--
NJKen
is a daddy!
Central NJ
Check those ******* plugs on the back of the head. Nows a good time.
Ken
geonc
SPIDER BAIT
Found it!
The stinkin' "vacume switch" on the fuel reg.......don't need it so out went the switch and in went a 1/8" brass plug with liquid teflon sealant....just snug ;Sweet
That switch is a "tattletale"......measures fuel restriction and lights idiot light when filter is plugged/dirty.
I use good fuel and LOTS of it and change the filter twice a year :thumbsup:
ealiaga12
