Suddenly
first post, been browsing since I got my truck. Already fixed the fuel heater leaking thanks to the forums here. Please forgive me if the format is terrible and hopefully the pictures work. Here’s the truck
I have had fuel leaking since I bought my truck and finally found time to try and figure out from where.got under the truck and found where it was dripping from and chased it back to the lines coming to and from the tanks. After giving them a wiggle to get a better look the truck now has a steady drip while running.
Tried a quick search in the usual places but was just getting results for the injector return lines.
This is just under the drivers side door
Second picture it looks like a metal line with plastic sleeved over it. Seemed like it was this line that was leaking, appeared to run up towards the return system, solid line underneath goes to the passenger side of the engine
Does anyone still sell these lines? Which is most likely to be the culprit? Is the sleeved line the return?
Thanks in advanced. Dan
